No Sound Through Rear Door Speakers
SunlitComet
OBS Jedi-Do Good
unknown at this time.
find a donor and rip the harnesses out from the rear doors to amp area to back in the dash. not just speaker wiring but power and signalling. have to include wiring for roof and p?wer feed inside the dash as well. in the dash are tho it will be time consuming to get it all in like stock because dash removal is likely needed to get an exact stock setup. any chance it is hiding inside the floor console underneath the compartments?
SunlitComet
OBS Jedi-Do Good
use the same year and trim level when getting a donor as 99-2000 will likely do but older ones had the harness and parts move a few times. can't remember right now if the 98 started the last move.
Diamondwulf
Not under the console as I do not have a console in the vehicle. And thank you for the info. I may just upgrade the stereo to a newer model and use an aftermarket amp and run wires for the rear doors.
mhessick
