2003 Chevy Tahoe LT 5.3 4wd
I’ve had this truck for about 3 weeks. It was having starting issues when I looked at it but it seemed to be a security system issue as locking/unlocking and opening/closing doors would let it start so I bought it anyway.
A couple weeks ago I replaced the radiator support and had the battery disconnected for several hours. I had the truck in neutral when I reconnected the battery and then the gear indicator on the dash began indicating off-by-one (indicates reverse when its in neutral, 3 when its in drive, etc) but it would still start at this point. I assumed disconnecting and reconnecting the battery while in park would reset the gear indicator so I tried that a few times, finally overnight, and that’s when it started not starting for anything (and still indicates the wrong gear).
Now no matter what I try it won’t start. Fuses seem ok, playing around with the steering wheel adjustment while trying to start does nothing, moving the gear selector through the gears while trying to start does nothing. I cleaned the battery connections, tried using a jump starter, nothing. Just a click from behind the glove box area.
I can't access the starter to check if voltage is making its way their at all. Blocked by the exhaust from the top and the frame from below. How to people replace these without removing the whole engine??? Any suggestions would be appreciated.
