[noise] drive shaft rubbing? - SOLVED
S
seatown
Seems to be tied to the speed of the drive shaft.
Was under there last night , joints felt pretty tight, shaft spun cleanly. Didn’t see any clear rubbing though
Geotrash
Dave
Richmond, VA
Sounds like either the starter or a cracked flex plate. A pretty common issue on these is the starter drive gear return spring fails and lets the gear bump against the ring gear on the flywheel. It's particularly noticeable under acceleration. Similar thread: https://www.tahoeyukonforum.com/threads/5-3-engine-tick-only-in-drive-reverse.148182/
S
seatown
Interesting
A little bit different noise, but same reaction to acceleration.
Before I replace the starter is there a way to confirm ?
Geotrash
Dave
Richmond, VA
Interesting
Yes, but it requires removing the starter and holding it gear end down to see if the drive gear falls down to the end of the shaft. But, if your starter is original, it's not the worst thing in the world to replace it with a new one anyway. Eventually it *is* going to fail, so it's one less thing to worry about.
S
seatown
madmoney
