Noise in driveline, pinion bearing?
D
dkad260
I looked back.. 120k on the rear?
interesting info
Yes.
I bought it with 90K and not long after I replaced all the fluids, the rear pinion seal was leaking bad, had to place cardboard under it every night.
I believe it was leaking before and may have been ran low.
The axle bearings, and axles were making noise and now this, so safe bet it was from low fluid...not sure.
j91z28d1
makes sense. when I last looked up the g80 diff stuff, it looked like guys were going 300 plus. and some saying 500k with just fluid changes and not abusing them. I'm no bearing expert, but that looks like it going to fail long before 300k.
Geotrash
Dave
Richmond, VA
Lots of G80s running around with 400K+ on the original bearings. Very unusual to need that kind of work at 120K miles.
D
dkad260
After many trial and errors, I feel this is the best pattern I will end up with given the shims on hand.
Backlash is right around .006, give or take a needle width.
Drive
Coast
Geotrash
Dave
Richmond, VA
Drive
Coast
That should run nice and quiet, and last a long time. Nice work, sir.
I did a similar job in April of '22 on our Land Rover LR2. They're infamous for eating pinion bearings on the rear diff, so it's considered normal maintenance. This one had a nice growl to it loud enough that the factory Alpine stereo could no longer drown it out.
D
dkad260
Thanks, fingers crossed.
Just wanted to verify the pinion rotating torque with a new seal. I have an extra crush sleeve if needed, but I'm at 22-25 inch pounds and I want to say max should be 19, but not sure.
I had 14-15 inch pounds and gave it a tiny bit more, and as they say...it builds fast...lol.
D
dkad260
Thanks.
Your chart is one that I've seen as much as the AAM gears showing 14-19 for new bearings.
The 23 felt tight so I went back and used the spare crush sleeve and I carefully approached my final torque of 18 inch pounds.
I preloaded the carrier bearings and ended up with .007" backlash, and a final rotating torque of 24-25 inch pounds. This puts me at right around 21-23 inch pounds for the carrier alone.
Ended up with a slightly better pattern as well, drive and coast are more aligned, drive moved off the toe just slightly but still biased to the toe which is good.
Drive
Coast
Just Fishing
Can't fix stupid
Utah
Landrovers are pretty.
Wife loved hers (freelander), but the BMW designed engine used glue to hold the cylinder inserts in the block...
Sure that probably would have worked fine, however the coolant that landrover used just happened to disolve that glue over time.
What you get is coolant in the oil.
The rule ever since is "Japanese or American cars only".
Only exception to the rule would be an antique, and maybe a Porshe 911 where I fully understand what I'm getting into.
But still, a Corvette is so much easier and cheaper to deal with. :jester:
valentinitoronto
