NON HEATED TO HEATED CONVERSION Q's
king 'kon
newton,ma
Is the harness there for the rears if you have the fronts heated? I have an 06 yukon and my friend gave me the heated middle bench out of a denali I know the back of the console needs to be changed for switches but what about the wiring?
ILLEGAL REGAL
Tinley Park, IL
I just bought a harness today, it doesnt look too bad to do but both rows of seats need to come out and pull up the carpet and rear plastic for rear a/c as the new harness replaces that floor harness with different harness' that run into the driver/pass door for the memory/heat buttons.
if you want the guys email let me know I'm sure if he doesnt have the harness he can get it for ya
oh and he got me for $100
ILLEGAL REGAL
Tinley Park, IL
I dont know a part#, he took it out of a denali so it has the harness for rear heated seats as well. If you have rear a/c find one with the rear a/c harness.
The harness is complete to front/rear doors, seats and rear a/c. Plugs in under the column and then there's a relay in the drivers side fuse panel you need to plug in. Also your door panels you can probably cut to install the heat switches/memory but I picked up 2 panels that came setup so I didnt have to cut anything to fit switches.
he's in Champaign IL
Coolwhip69el
