NORCAL SS 1-2.5/3.5-4.5 2wd/4wd kit.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the rear spacer used?
Cmicasa the Great XvX
All I want is a smoother ride in the rear without lowering. Current situation over bumps. Setup is trailering, 20inch wheels, with autoride. If I just changed the shocks I'm gonna get the service codes. Is the bumpy ride coming from the shocks or the springs?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Without lowering... good luck
2016YUKONSLT
What is the difference between this one and the other thread that needs new spindles?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
4x4 kit rears same just front uses relocaters or I can set up with drop struts
2016YUKONSLT
Not sure I understand the difference. I have a 4x4 and would like a 2/4 drop and hope it levels out some.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if your 4x4 and want 2 inches i would do drop struts and the camber kit thats 275. then in rear you can do my 3.5-4.5 kit which is 360 shipped and you will need to cut the bracket off the frame and bam ready to roll
Kaylor123
