NORCAL SS 1-2.5/3.5-4.5 2wd/4wd kit.
2016YUKONSLT
Do you have anything that doesn't require cutting, just in case I decide in the future to jack it up 6" and put some swampers on it? Just in case I find a large puddle at the local shopping center...lol
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
swaybar brackets you can put into the stock holes which is cake.
in rear if you go not the full drop you dont have to cut bracket off frame
any mods you do with lowering will not change anything when lifting in rear. You can put a 6" kit no issues if you decide lowering is not what you wanted
2016YUKONSLT
So the bracket that you cut off is just the bump stop bracket? It isn't for anything else? Do you have an install video?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Google Tahoe free travel mod all you do is cut that bracket. with my kit I then include new bumps tops that bolt thru existing holes already in axle pad so you don't bottom out.
You get tons more travel doing this
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Nope. I will have the first belltexh batch probably late jan
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
I have milled the older spindles and they fit. I sent info to belltech and told them what needs to be done.
lynxnova
New Jersey
Thats great news but I thought belltech already had new ones in production coming any day now.... or are they just gonna remilled all the old ones from the last model .
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The test model didn't go as okanned. I'm hoping they can work off info I gave em
Kaylor123
