normal operating temp
TheBeast99
ok, i was just curious if the pump was still mechanical too :)
to see if my gauge was anywhere near correct, i was thinking this might help -
http://www.skymall.com/shopping/detail.htm?pid=203072829&c=10112
i was thinking of buying one not just to check temps, but for all the other stuff it does too! and i can either leave it right on my dash, or stash it in the center console when i think someone might jack it from my truck...
ChrisInWI
SW Wisconsin
Umm, yeah.....stash it in your center console....umm where do you live again?!?!:flamingdevil:
blueflamed03
Oklahoma
if you have a 195, it will go up to 210, maybe a tad more, then it should open up and lower back down to 195-200, but that's normal.
riviera rider
i just noticed mine goes up to damn near 250 mark before it finally drops down to like 130, what is wrong?
fyremanpat
Fyremanpat
if its going all the way to 250 and dropping down thats your thermostat.
Grebbler
Parts is parts...
Michigan
Wonder if a hose is collapsing. When a temp meter fluctuates is gonna be the meter, sender, T-stat, fan clutch / E-fan, or air pockets going by the sensor (low coolant).
Make sure the heater is on, both front and rear, before topping the coolant off.
I read somewhere that an air bubble can be a ***** to get out of these trucks, sometimes.
I hope it's something simple - and cheap.
riviera rider
ya well im going to change my thermostat and see if it fixes it, if not im gonna see if theres a sensor bad somewhere maybe
but ya it stays below 150 i know that for sure, but yes it definetly everytime hits around the 250 mark and takes for ever to get the heat blowing in the truck
Lowbrad
