Just remember, they are front and rear and left and right specific.Im going to order them tonight thank you all
Lots of people swear by them. Interestingly on my 2007, none of the exhaust manifold bolts have broken yet. I've been considering replacing them with ARP bolts proactively just to avoid the problem completely. This thread may get me off my butt to do it.I have 3 of those exhaust clamps, by Dorman, on my rig and they work just fine with no problems at all.
I am in the same boat with my '07.Lots of people swear by them. Interestingly on my 2007, none of the exhaust manifold bolts have broken yet. I've been considering replacing them with ARP bolts proactively just to avoid the problem completely. This thread may get me off my butt to do it.
In the same boat with mine.. If it aint broke, I aint gonna fix it..I am in the same boat with my '07.
One of these days I am going to get all energetic and replace them with ARP's. Just not this day.![]()
You can’t say that for sure. There’s been many on here that sound exactly like that and it was exhaust leak. Mine included. I could have swore it was lifter noise.I bet when your all done it will still make the same ticking noise. Buy a mechanics stethoscope from Harbor Freight. You will find the ticking is from a lifter. Could be a lifter or rocker arm issue, but that ticking is definitely valve train.
I think changing the O-ring is more about oil pressure than anything going on with lifters. Adding the AFM oil pressure relief valve deflector is a good idea on engines that were made before they started installing them at the factory.I have been chasing the same issue. I read on another forum that a guy with his wife’s suburban doing this, and he pulled the oil pan, then the oil pick up tube, and changed the rubber o-ring. Supposedly this fixed the tick but I’ve yet to do mine. I have also heard about a TSB for adding an oil distribution hat while the pan is removed, which for a few dollars should be also done while it’s pulled apart.
