So I purchased an HID kit for the 09 Denali. First off, the product came and looked of high quality (except its not a plug and play system)....untill I installed it. Simple install, no issues except with maybe the access without removing the fender well and tires. Installed everything and made it all tidy...then I fired them up only to have one side work...no biggy. Swapped bulbs to see if it was the ballast. Ballasts were not the issue. Ordered two more so that I would have a spare...only because i'm the type to have spares for EVERYTHING because now days, Quality control has taken a back seat to profits.
Two new ones show up. Replace the burnt one....the new replacement flickers, then goes out. Let sit, fire it again and it does the same thing. So much for that one. Try the other one, thank god it works. Finally I have two beautiful 6000k HID fogs. Two days later, the other original one flickers and dies and now stays lit for a few minutes. NOT IMPRESSED.
Is there another system out there that someone recommends cause this one is going back.
