Nothing is going right for me. Need a little help
992door
992door
Greenville, NC
No it does not slip once it is in gear. Fluid looks decent as far as I can tell it is dark outside
96ProCompTahoe
IN
may be something as stupid as a clogged filter. i'd get ahold of the shop and have the drop the pan and take a look (hopefully they will just do it without charging you with the low milage)
dads s10 clogged a filter and wouldn't stay in gear, we limped it a hell of a long way and ended up burning out the trans. trans shop said they probably would have been able to save it if we didn't overheat it so bad.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
These two came to mind but if you are getting noise an internal leak or like procomp said blocked fluid flow may have caused a lack of lubrication and is ruining hard parts now.
Slow, slipping or no reverse “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell.. May also have worn boost valve. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the Transmission may help (must remove valvebody), or adding a high-viscosity additive such as Lucas Transmissionmission additive or other seal restorer product.
1-2 shift does not happen at WOT until you let off the gas. Middle case leak in the 2nd gear apply circuit (servo assembly or 1-2 accumulator). Doublecheck by using the pressure gauge and watch for a big drop when the PCM commands 2nd gear. Worst case poor line pressure rise (see below). Try replacing the ThrottlePosition Sensor ThrottlePosition Sensor (TPS).
mneff911
