Now I've lost interior power
MassHoe04
Western MA
Members weren't kidding when they would tout the benefits of buying a Tech 2 (or finding a friend with one). I thought is was all hype, but having seen how it can speed up DIY diagnosis and save time/money... They were right on!
The Tech 2 can tell you all kinds of things about components like your power windows. Volts in, active/inactive, motor status, etc. You can even command widows up and down even to see how things respond.
All of the information these can give you access to can allow quick and easy diagnosis of many things before getting any tools or multi-meters out.
At least, so far, you got it running!
the pcm doesn't care what vehicle it is in as long as the 8th Vin digit is a match, you could throw it in any matching gmt800 suv or pickup
same for a engine swap, that's how lkq, junkyard etc match up engines and ecm's
AND again this would not affect your interior power, not possible. That is controlled by the BCM (body control module)
you might be confused to think a vin T engine would run any different in a pickup or a suv, THEY ARE THE EXACT SAME MOTOR, so because the pcm came out of a pickup or SUV does not matter at all.
Coolwhip69el
