Nv4500 going into 99 2 door Tahoe
99 2dr
99 2dr
The Real Nor Cal !
Last night the clutch pedal went in. Overall it was pretty simple, took about 2 hours start to cleanup. To make more room I moved the ECM and the under hood fuse block out of the way. I used a 1-3/4" hole saw to punch the hole in the firewall. The clutch pedal and bracket installation were a little harder due to the size but really not a big deal. I just wrestled the bracket up in there and bolted it down. I did not have to remove any of the dash components to install the pedal; however removing the Main Bezel and the cover below the steering column would have made it easier to see. I will need to throw a couple zip ties up there to hold the main harness in place for good. As of right now the pedal swings freely.
96Yukon, If you get a 2wd Nv4500 you will need a 4wd main shaft and transfer case adapter from a NV4500. Also you will need to change the input shaft in your transfer case.
Here are the latest pics.
96GMCYukonGT
thanks for the info guys sorry for jacking your thread aswell
99 2dr
99 2dr
The Real Nor Cal !
Sunlit, I ended up using a stock clutch from napa for a 99 k3500 with 5.7l engine. I thought about going with a heavier duty after market clutch however the k3500 is rated @ towing well over 10,000lbs and max towing on the Tahoe is only 6500lbs. If I have any problems with the stock clutch my napa store manager will warrantee the clutch set for me and I will order an aftermarket set.
I'll get a complete parts list and pics up in the morning. The swap ended up basically being a bolt in job. The only thing that I have left is the clutch safety switch wiring.
Sunlit, is there any chance that you could get a hold of the clutch safety switch wiring schematic for a 98 k1500-k3500 4wd 5.7l engine.
Thank you,
Kyle
99 2dr
99 2dr
The Real Nor Cal !
Here come the pics!
Here are my pics from the weekends swap! More information coming soon.
99 2dr
99 2dr
The Real Nor Cal !
Here are the rest of the pics.
I must thank:
98whitehoe- Chevrolet Forum
GM Guy- The Truck Stop Forum
SunlitComet- Tahoe Yukon Forum
:hands: :driver:
blanchard7684
