Update
My swap is almost 100% complete. I have removed all of the under dash automatic shifter components, shifter cable and park position key lock out.
For the start safety switch I located the purple and purple/white wires on the automatic trans range switch and wired them together. I then found the purple wire and spliced one side to each pole on the clutch start safety switch.
Things left to do:
BB tune. This week.
Find a manual transmission cluster. Err the park indicator light is driving me crazy!
Wire up the clutch cruse control kill. Err, its embarrassing when your driving on the freeway, push in the clutch and bounce it off 6K!
Swap the brake pedal or cut off the automatic one and replace the pad. The pedals aren't at even heights so I might try swapping them.
Service transmission and transfer case.
Sunlit, would it be possible to get a Cruse Control wiring diagram for a 98 K2500 5 speed?
Thank you,
Kyle
