NWS: Yukon Denali '07 2/3-4 Belltech or JDM?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the rear kit comes with new bumpstops that are shorter.
the truck has autoride on it if so if they didnt plug the sensor in or broke a sensor line.
T
ThaHooch
Damn, you're quick :)
So, the only thing to do to acquire the 4" drop, is lift up the rear and pull the spacers out?
I figured the warning had something to do with the autoride...is that the only thing that would throw the warning. Also, any saftey concerns if I don't get that fixed right away, because I have to drive across a mtn pass this afternoon. Again, appreciate your help!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes just pull spacers out and make sure the autoride links are about 3 inches from center to center.
make sure the front shocks have the autoride clips in. Also did it happen when front was done or rear?
T
ThaHooch
Not sure, they did front and rear at the same time yesterday...
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yup somethings not right either they didnt hook it back up right or broke a line.
Front spindles dont affect the autoride system at all and rear with shock extenders in the shocks work like factory.
T
ThaHooch
Yup, they broke a line. I heard some rubbing in the right rear, so when I looked to see where it was rubbing, I spotted the broken line. The right rear is sitting about 1/2" higher than the left, which is strange, because that's the side that occasionally rubs :whymewhyme:
EDIT: Here are some pics. Is this the correct link that came with the kit or did they leave the OEM link in there?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
correct link but looks like they destroyed it.
What you can do is go to a hardware store get a machine screw that is alittle bigger and it will thread right in.
it looks liek they bent the hell out of the mount when pulling it off.
Leonidas
What's Good TYF!!!!
North Carolina
man that is what scares me...take your pride and joy to the experts for an install and they do that shit:emotions122:. ***** the ride looks good by the way. Give more pics when fixed please.
KMeloney
I bet the right was higher in stock form, too. Mine was, and still is (after the 2-3 drop). Most (if not all) of these trucks are higher on the one side...
I'll be watching this thread, because I want to go a little lower in the rear, and will probably just pull the spacer first, but want to see if I also need to go shorter on the links, etc...
T
ThaHooch
Thanks Tony, found some all thread at work this morning and fixed the problem before my appt to take it back to the shop this afternoon. I made the all thread 2.5" long, and I think I read somewhere (maybe this thread) that the link should measure 3" from center/center...am I measuring this right?
Here's the fix in place :)
Thanks! I'm shopping for wheels now, so I'll post some pics when I finally pull the trigger.
I haven't driven anywhere after installing the new link, but I did start the engine, and the passenger side is still a bit higher, but by less...there's about a 3/8" difference now.
I'll post updates if I take the spacer out :Handshake:
ElwoodNotJake
