OBS wheels on NBS Hoe??
Tahoe02Yukon04
Birmingham, AL
Stumbled across some free OBS wheels, thought about putting them on NBS Hoe just for a change. They are Hollander 5015 wheels (see pic), will they fit on my 2002 Hoe without any probs or adjustments?? I think both are 6 x 139.7 but not sure they will fit. Thanks!
DirtyBlackHoe
Thomasville, GA
I am pretty sure that the hub is too big to fit thru the center of the wheel. I remember in college a buddy of mine wanted to run my Z71 wheels on his 2000 regular cab and they wouldn't fit due to the bore on the centers (I hope I used the right terms.)
Gzes
the drifting 2dr
Wichita tx
Could work with a little work. Would look pretty good aswell. As log as the hoe had 16s from factory because the newer hoes have bigger brakes and rotors
Tahoe02Yukon04
Tahoe02Yukon04
Birmingham, AL
Ok, I'm hearing a 'no' from TYF but conflicting responses elsewhere. I even went by a local Chevy dealer to ask and they seemed to think the OBS rims would fit fine on the 02 Hoe, no problem. Looks like both are 6x5.5 bolt pattern and 16x7. Why would they not fit?? Thanks for any and all help!
More info...
The OBS wheels were on a 1994 Silverado up until a week or so ago. Not sure if they came original on that truck but thought that might help. Thanks.
Gzes
the drifting 2dr
Wichita tx
Center bore is what woukd make or break. I believe the newer hoes have larger bore
97TahoeLT
Arizona
one time I tried to put my 1997 wheels on my brother's 2001 and didn't fit.
Sent from my LG-P768 using Tapatalk 2
Tahoe02Yukon04
Tahoe02Yukon04
Birmingham, AL
Can you try them on?
Possibly, just thought I could save the trouble if they won't work.
---------- Post added at 11:30 AM ---------- Previous post was at 11:28 AM ----------
Thanks, 97TahoeLT, do you recall what the problem was? I've tried to locate the specs of each rim and it looks like the offset may be different but that's all I've found. Looks like the center bore of each is 78.3 so that shouldn't be a problem. ???
