Revive for help!
Reviving this thread for help on a very similar issue as the one described.
98 Yukon SLT 4x4, 135000 miles.
Originally, I though my problem had something to do with my "Security" light constantly illuminated. I've had to go through the re-learn procedures several times before reaching a stable security position. However, even during the most frustrating PassLock II issues, the fuel pump would prime each and every time I turned the key. Only lately has the condition below been increasing...
At this point the 3 second prime occurs roughly 10% of the time. The remaining 90% of starts requires hammering the starter for up to 30 seconds before the oil pressure rises enough to activate the secondary circuit. Even when the engine is hot, it sometimes fails to re-start on short stops without an extended crank. I've checked connection from the relay to the VCM and everything looks fine there, so perhaps my VCM is going out?
After the oil pressure switch takes over, the engine runs perfect with absolutely no sluggish performance; telling me that the fuel pump is working fine and the relay remains engaged, so I'm leaning towards the VCM as the culprit.
I'd appreciate any input on how to test this theory or maybe someone out there has resolved this issue by creating their own 3 second primer circuit trigger to replace the one sent from the VCM. I'm no engineer here, but I believe a delay enabled relay would be all I need to make it happen.
The diagram I have of the fuel pump system seems to consist of the mechanical circuit and the VCM circuit tied together. A single relay for the VCM method remains discharged during the initial prime and is activated only when the oil pressure switch completes the ground to the coil.
The only thing I don't understand is the RED wire labeled 490 "Fuel Pump Prime Connector" and what the "Fuel Pump Balance Relay" is.
