Odd Idle problem.
Fless
Super Moderator
Elev 5,280
What brings you to the conclusion that it's the fuel pump's fault?
S33k3r
Dallas, Texas
I thought you tested it at 48 psi? I may be misremembering, but aren't we supposed to have 60 PSI?
Fless
Super Moderator
Elev 5,280
He measured that at idle. Typically these run in the low to mid 40s (43-45 psi) when the engine is running, as long as the fuel pressure regulator is working properly.
SpareParts
SpareParts
North Idaho
Yes, Idling FP was 48psi. I did not try it KOEO nor did i try snapping the throttle and i did not unhook the vacuum line either.
Regardless the first thing i need to change is the Fuel Filter, At 180k im pretty sure it has never been changed. After changing that i'll check it again.
tdeaton3
