OEM paint in a rattle can?
godoy
godoy
utah
Automotive touch up matches my Burundi blue metallic perfect, I reprinting my whole bumper with it because it's such high quality
Thanks , you gonna paint the whole bumper with can or spray gun??
Where can I find the paint code?? On the side driver door??
Sent from my HTC VLE_U using Tapatalk 2
godoy
godoy
utah
Thanks ill be ordering some cans but will have to find some time to take my Door handles off
El Capitan
Senior Texas Member
Grapevine, TX
Duplicolor would not recommend don't know where your located but here in DFW we have a paint and body supply store called english color and they'll mix any color and put it in a rattle can. If you can find a store near you or similar would definitely recommend getting ppg in a rattle can. Mainly because gm used ppg paint on our trucks.
---------- Post added at 07:46 PM ---------- Previous post was at 07:41 PM ----------
btw the door handles aren't that hard should be 2 7mm in each door panel and pull up on the door panel not out. Then either 2 or 3 10mm bolts for door handles then just disconnect the linkage.
godoy
godoy
utah
thanks, havent heard of that store here
never done it but sounds pretty easy its like putting on a speaker right:Handshake:
RedCrush
If you go to a pep boys they normally have more popular colors there in a can. all i can say it prep is key. lightly sand (1000 grit or more) your door molding and handle. clean with some thinner and a lint free cloth. and you mightwant to spray some bull dog on there first. once that dries spray your color.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
duplicolor makes them too. I got mine from autozone. Even Napa carries them
tdeaton3
