Off-road Lighting Idea
TheAutumnWind
TheAutumnWind
GulfCoastTahoe
Biloxi, Mississippi
Sorry! 4 on the roof rack and then 2 in the grille. Do they put out more of a spot or flood type light?
---------- Post added at 03:09 PM ---------- Previous post was at 02:58 PM ----------
So, for now I think the plan is to buy 4 of the Blazer 6" and then 2 of the blazer rectangles for back-ups.
If I'm wanting to add the behind the grille lights later, will it be remotely easy to patch them in?
I'd honestly like to run the set-up with 3 separate switches.
One for grille lights, one for roof rack front lights, and one for roof rack back-ups. Sound reasonable?
TheAutumnWind
Sounds very reasonable. Run a relay for each of those. Make sure to run heavy gauge power wire and sufficiently sized fuses, your talking about 400w of draw for the roof lights alone.
Oh and the wiring from the switch to the relay does not need to be heavy gauge as it is simply to trigger the relay and does not carry the load of the lights, which is the whole point of a relay of course. Not sure if your aware...
Keep in mind You'll likely need more wiring than you think if you want it to be tucked away nicely.
Adding grille lights later wont be a problem.
They are more of a spot light. Certainly not super focused pencil thin type beam, but they have plenty of throw. With the 4 on your roof you may like to have the two outermost lights turned outward a bit.
For the reverse lights you could tap into your factory backup lights and use that to trigger a relay if you would like them to come on automatically when you back up.
YukonXL04
The Riverboat
Arlington, TX
sounds reasonable
---------- Post added at 03:25 PM ---------- Previous post was at 03:20 PM ----------
looking like you need 6-8ga wire for those 4 roof lights. 33amps
TheAutumnWind
sounds reasonable
Yeah I was planning on running 10ga for each pair.
TheAutumnWind
I got my lights, and fuses from this seller if your like me and too lazy to drive to the store.
http://stores.ebay.com/enniselectronics151/
---------- Post added at 01:51 PM ---------- Previous post was at 01:46 PM ----------
I would probably run a 4ga from the battery to a distribution block, then relay out from there with 10ga to each pair of lights.
That would be ideal.
GulfCoastTahoe
Biloxi, Mississippi
Thanks for all the input guys. I'll hopefully be able to knock this out at some point this month. Just depends on your schedule, Shawn haha As I've stated earlier, this will be my first time working with electrical components like this, so I'll need guidance:sorrysign:
Djohnson99
