offset to run
ruddersdenali
sup peeps. thinking about ordering some wheels for my 03 denali. i am new to the truck seen and i would liek to get some 24's but i just dont know what offset to run dont want it to stick out and i also plan on sropping the truck with a 2/3 drop
MissCB25
Austin, TX
Running 24's on 305/35R24 on my 08 Tahoe, upgrade from stock 20's. Check out this website- it will give you some info on how the clearance will change with different sizes and offsets. The offset on mine only changed about .4mm from stock and they are a little wider but don't stick out noticeably. There are some good threads you can search on here as well.
http://www.rimsntires.com/rt_specs.jsp
Only thing I've noticed switching to the 24's is that they rub the plastic clip in the front wheel wells when clearing tight turns, no harm done though. Hope that helps :)
BOSS
The People's A D M I N
Dallas
The offset you want is 13-15mm+ for the NBS. Word of caution, when you drop the truck make sure you get the Z71 bumpstops installed on the control arms up front. IF you dont, you'll bottom out into the fenders on big bumps.
(GM part no. 15161762, you need 2 of them)
B
R
ruddersdenali
Thanks BOSS, i did a search and seen some peeps running 30mm with 24inch wheels. i think the guts name is titanium on here with 24inch u2 55 wheels. I am definitely thinking about getting the boss 313's in 24 inches. You think that should sit right with the fenders dont want it inside the fender want the wheel sitting flush
BOSS
Dallas
With a 2/3 drop, +13-15 offset for flushing the wwheels.
If you run the +30 on 24s, you will definitely run on the inside plastic pieces and it will annoy you. With the 2/3 drop you can get away with the +13-15 without too much trouble from bottoming out - PROVIDED you get those z71 bumpstops. Theyre like $25 each, cheap insurance and peace of mind on big dips.
B
R
ruddersdenali
Boss thanks again for the in depth info i will def do +13-15, with those wheels and the drop. also a buddy of mine will pick up the bumpstops for me.
R
ruddersdenali
Sweet man truck looks good. I will be getting my wheels in two weeks went with boss 330's in chrome.
gottaluv01tahoe
