LionsGuy
- Joined
- Feb 9, 2019
- Posts
- 17
- Reaction score
- 3
Hey guys, well my ride is a oily mess underneath and i know its probably a few different things, but I am going to start with the oil cooler block-off plate.
Questions I have.
1.Can I change this without changing oil?
2. What are torque specs for 2 10mm bolts?
3. Can I just use the gasket and no RTV?
4. If RTV is needed how and where to apply?
Also other leaks. On the other side of the pan on the starter there is oil, not on top of it but bottom of it. What could it be? Also I'm sure i have a bad pan gasket but is there any way it could have seeped on the starter, or my worst fear in the Rear Main.
Cam sensor, and Oil pressure sensor will be changed in the spring with my Manifold gasket swap as added info.
Oil seems to leak most when just driven, not when just sitting for awhile.
Thank you
Questions I have.
Thank you
