Oil cooler lines leak?
992door
Greenville, NC
Did you put the o-rings on the hoses when you replaced them and are they seated good in the fitting?
992door
Greenville, NC
Just to make sure we are taking the same thing. You replaced the 2 hoses that run into the radiator?
992door
Greenville, NC
OK I am pretty sure that there should have been o-rings to go on the connections. Sunlit would probably know for sure whether they should have them.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there are orings used on each line where the lines enter the radiator and there should be internal orings on the fittings where the rear portion of the lines snap into the quick disconnect. the ones in front are available individually for a $1 or 2 each from a dealer and those should have bee included with the lines. the one in the back the whole fitting must be replaced. those are about $8-10 each gm 15043741.
---------- Post added at 07:48 PM ---------- Previous post was at 07:46 PM ----------
4wd version shown. only difference between the 2wd should be the adapter orientation.
http://www.genmotorinfo.com/Picture...S+(L30/5.0M,L31/5.7R)+-+K+&pid=960515TC01-018
4myfreedom
4myfreedom
Washington, DC
No have to take my bros yukon off the lift. New engine install will keep you posted. sorry its is so slow
hosleyb
