hi
my 2004 yukon denali with nearly 200000 miles started a oil leak from the seal.
i think it came after i had an engine overheat to around 240-250.
what i did trying to fix it:
1. changed the seal ( gm seal) - still leaking
2. changed the seal again just to make sure the first seal wasnt damaged - still leaking
3. changed the front cover and Harmonic Balancer with new seals and gaskets - still leaking
the engine has low pressure oil, when cold 40 psi but it will drop to around 10 psi when idling and hot, when accelerating it goes up again.
i changed the pick up tube o ring but still the same.
i did some research and i might have bad cam bearing but fix it not in the budged right now, so my question is there anything else i can try to fix this issue before tearing the engine apart.
