iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 815
- Reaction score
- 437
+1. I find that oil change shops seldom reset the oil life minder.Is it possible the monitor didn't reset and now you are just seeing lower than before? I usually change mine at 5k, which is somewhere around the 40-50% oil life left per the truck. I occasionally forget to reset it, but don't really use it other than a check point.
I did reset the oil life gauge bc it was at 40% when I changed it last in August and there’s no way it used only 3% in 5-6 months.+1. I find that oil change shops seldom reset the oil life minder.
My solution is to change the oil every 5K miles at 100K, 105K, 110K, 115K, etc so it's easy to remember.
I did reset the oil life gauge bc it was at 40% when I changed it last in August and there’s no way it used only 3% in 5-6 months.It used 63% that quickly? When do you normally change the oil? By the monitor (if so what %), or by mileage?
If you did reset it, then my assumption is that lots of short trips with idle time in cold weather could cause that. There are all kinds of inputs that go into the calculation. The oil looks decent from what I can see.
How my truck used 63% oil life In less than 2k miles basically. Did oil change myself and reset the oil lifeI'm not sure what your question is here.
