Hey all,
I have a 2000 Tahoe Limited, right around 205k on it. Runs and drives great, but has had an oil leak for the last 50k miles. Started when I had to replace the front main, in which case I did the whole cover with the seal. Put in a new Felpro gasket at that time, and has been leaking ever since.
The last Felpro gasket, I had a buddy who was a mechanic take it to his shop, and he just gooped a bunch of sealant on the front and rear. It worked for a bit.
The gasket I installed was Felpro OS34500R. I installed it with no sealant, as that is what the directions called for. Took my time, made sure the gasket was aligned at the front and rear ends.
And upon initial start up it was leaking still from both the front and rear.
I did a little bit of reading and it sounds like these Felpro gaskets are not the greatest, anyone else have experience with it?
I've also ready that the timing cover can be the issue, which I have a plastic doorman unit.
So I'm contemplating buying a metal cover and going with an AC Delco gasket.
Anyone have any tips? It would be nice to have one car that doesn't leak oil.
