Oil Pan Gasket Leaking
Jason in DLH
Jason in DLH
Cheeseburger and Fries
MN
Thanks for all the help everyone! If it weren’t for you all I would have torn apart the whole oil pan to change that gasket. I don’t believe it’s the rear main seal (everything is completely dry up in there and I even put my finger inside and there was no oil)...
Saw some oil up around the oil cooler block off gasket (didn’t even know it existed until you all pointed it out). Ordered up the gasket, RTV gasket maker (just to be sure I nip it in the bud), and a 24” extension for the ratchet.
89Suburban
Bull in the china shop
SE PA
Let us know hos it goes.
JonnyTahoe
Minneapolis
I will take a picture of my oil pan so you can see what a rear main leak looks like. Do you have oil all over your crossmember? Bottom of your fuel tank? Clear back to your muffler and Rear Diff Housing? I do that's a rear main leak.
Jason in DLH
Jason in DLH
MN
I did replace the block off gasket a couple nights ago...
I used a 24” extension with a swivel and one of those ratchets that the head can adjust which made it possible to remove the part without removing the tire or inner fender liner (was able to sneak right through)...
It was actually quite comfortable leaning my arm against the tire. The angled ratchet helped so it wouldn’t hit the tire.
Jason in DLH
Jason in DLH
MN
Yeah...sounds like I definitely do not have a rear main seal leak! Would like to see a picture of it though..
jfloare
