InspectahDEck
- Joined
- Oct 15, 2013
- Posts
- 74
- Reaction score
- 66
Loss of pressure confirmed. I bought this block tester and the test came back negative, fluid remained blue. It's odd because the engine does not overheat, it sits around 208 deg. The coolant loss is minimal. I checked the dip stick and the fresh oil I put in has not became milky. There is no visible coolant leak externally I can see, I park in the garage and the floor there makes it easy to see if anything is leaking.
Could replacing the intake manifold gasket somehow cause coolant leaks? Not sure what else would cause this coolant leak to randomly start.
