Oil Pressure Issue - Resolved
Geotrash
Dave
Richmond, VA
Yes, on the carport, using floor jack- then used same jack to muscle it back, using zip ties to not loose progress - not my most proud moment
Hey, whatever works! But having done the job 3 times now, I never needed to remove the diff - just needed to drop it down on the passenger side. Waaaaay easier. I'm mentioning this for others' benefit who might read this.
Geotrash
Dave
Richmond, VA
@Geotrash At the risk of looking stupid, yes. But! I was also installing a diff drop at the same time so it had to come all the way out. Is there a better way??
Ah, that makes sense then.
Yeah, you don't have to remove the differential on 4WD/AWD models to get the oil pan off. All you have to do is remove the axle shaft bolts on the passenger side and separate the CV axle from the flange. Then remove the 2 differential mounting bolts on the same side. The differential will hang plenty low enough to wiggle the oil pan out without having to drop the diff completely. Confucius say: "If you want to know the easiest way to do something, watch a lazy man."
Dustin Jackson
@Geotrash This is great information, I will be sure to pass it along.
jkiger95
