Hey Fellas
Long time browser first post on forum. Have an oil pressure issue that I cant track down and it's killing me. Have a 2007 Yukon Denali with a 6.2 vvt non DOD. So stock motor was pulled with 255k due to bad rear main seal leak and bad tap and piston slap. Got my hands on a clean l94 with 60k miles. Did a 156-401 Comp cam, 7.4 btr push rods, ls7 lifters and trays, trunion kit, dual valve springs, new oil pump, pickup tube gasket and oil pan relief valve.
Truck now runs great piston slap is gone and all noise is gone. When motor was first started until oil pressure was 65psi cold and sat at around 45 psi hot idle. After 500 miles changed oil and went with 5w40 rendline syn and found a bunch of flake in oil which is pretty standard for new parts. Now when I am driving I have around 30 Psi when hot driving and it falls to like 15psi when warm idle sometimes 10-12. Startup cold is 45ish psi. Swapped sending until and still no dice. I am not sure what to do at this point.
Dropping pan today to check pickup tube and o ring. When the truck is idling hot even when oil pressure drops all the way down no abnormal sounds like a vehicle with low pressure. Any idea's? Trucks killing me now runs though and i love it but I was hoping i'd be past this by now.
