My 2000 Limited has 201k miles. Runs and drives great, but has an oil leak from the oil pan gasket. I'm planning to drop the pan and replace the gasket soon. And I've been reading that the oil pump should be replaced.
When I look at rock auto or some of the other parts sites there are a slew of pumps to choose from.
Looking for advice and input as to what others have used.
Currently, the truck has a little more than 20psi at idle, 40 cruising at 40mph. So it seems that my pressure is fine, but figured while I'm in there, might as well. Preventative maintenance.
Thanks in Advance for any input.
