OK someone tell me what this noise is
I took out my GN after sitting over a month and the rear bushings were squeaking like a pissed off mouse. Drove it around a bit and it quieted down. Yours sounded exactly like that towards the end of the clip.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Creek sound. Check your Lug Nuts. Sounds like a loose rim
Delco PA
I can really only hear it while your turning. It sounds like your cv shaft is going bad binding up. As your moving and turning its trying to flex the joint but its starting to dry out so it squeeks as it moves.
I would agree with him on the cv joint. Also check hub bearing. You don't have a brake pulse do you?
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
This. You have loose lugnuts or the wheel is not flush against the hub.
Pull the wheels off, clean the hub and the back of the wheel and torue the wheel in the star pattern to 140 lb/ft.
nharkey85
Alabama
Check to make sure the rotor/caliper/pads on that corner are good, no weird wear pattern. There's a small dust shield in there on a 2wd.
Loose lugs for me always made a loud "clack" sound, but if the wheel is rubbing on the stud it might sound like that. Should be able to feel a vibration though
Chadricckglenn
