only getting 9 mpg help
J
jefff82
kingman az
not sure what kind of tires your running, but 44psi is usually the MAX psi for a tire. unless its load range E. the door jamb sticker on my two NNBS's are 30psi and 32psi.
other than that. extremely easy pedal from a start. I strive to keep my rpm under 1500 at all time. 60mph max.
Really easy on the pedal like rangel said and got 14.06 last check. Haven't changed anything just easy on the pedal and that's around town driving to work. Just easy on the pedal. I can live with 13-14 mpg city. 9 was a little extreme for a stock/small tire Tahoe thanks
GM iraqi
My friend I have the same car u have
If the car running well with no problems
It might the fuel gauge is not reading well or the milage cluster so in this case re do the test by using the trip button and compare the results
ButtlickerPrices
