Options for 2wd lift?
Big Roller
Tennessee
I've been looking around for a while for a decent lift and found this one --
http://www.roughcountry.com/gm-susp...JadhJeQIAqm9gYJ0BAzShZiknnEKA0pt4SxoCHSzw_wcB
Is this a good option for my 2wd? And would I be better off adding a leaf in the back instead of using the blocks? The packs are worn, but I think I can get away with adding a leaf or two and get some firmness back too. I'm looking to do this and add General AT2 31x10.50's with my stock wheels to add a little more height as well. Maybe even bigger tires if I can fit them.
B
Big Roller
Tennessee
Should I get taller leaf packs and not use the blocks? I believe I'm gonna have to do some other front end work before I get the lift, I'm just getting some more info on the lift before I jump into it.
cmvash
Thought I'd piggy back on this thread since I am looking at leveling out the front end of my 2wd two door.
Basically, I'd like to bring the front end up about 2" so that the vehicle is level - would coil spacers be the simplest way? Should I be concerned with the UCA's at a 2" raise?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
never go above that because the rid will be a little harsh already. 2" or more should really have a kit installed to avoid drivetrain and suspension damage.
dylansmashed
