Yea, that Denali cluster I found close to here. is out of a 2001, was $125 just for the cluster.
No, mine's a 2005 Z71 2WD package. Only year they made those. 200,000 miles and still going strong. Preventive maintenance is the key.
Roof rack lights were a mod I did using halogen lights I got off Ebay. Hooked them up to the trailer hitch wiring harness with a switch under dash also for lighting things up really good at night. Really good for putting the trailer ball directly under the hitch at night. With backup camera of course.
Swapping the cluster for the tranny gauge is an option, but more expensive and you will still have to have it reprogrammed for correct odometer reading. I put in blue LED's in mine at the same time.
Wheels are 2007 Yukon.
I always thought they originally meant to do that.Yes, here is a picture of what GM had made to go there, but the govt wouldn't let them do it.
Denali cluster also has it if you can't find or don't like the Escalade cluster. Yes- plug-and-play. Hell, I plugged a Denali cluster into my '02 S10 and the trans temp gauge worked. All the gauges worked, tach was off (S10 was a V-6).
Pretty sure you'll need a late-year '03 or '04+ cluster, though. You'll also need to have the mileage programmed.
True.I think the 2500 hd trucks had transmission temp as well, if he wanted to keep a more stock look
I am assuming you mean the 2500 HD trucks with the gas engine and not the diesel?
