95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,155
- Reaction score
- 4,455
The outer window seals on my front doors had seen better days they looked crappy and the felt on the back side that wiped the window was missing in places so I picked up the replacement outer window seals for both front doors from LMC, took off the mirrors and door panel so it was easier to do this (not sure if you can do it without doing all that? had to replace the mirrors and did them at the same time) the new seals snapped on and fit perfect when they were first put on, but now about 3-4wks latter if you look at it the seals have some waves/ripples in them, its not all flat and level like it should be maybe the sun caused this? has anyone else had any problems with this before? cause my old OEM ones fit perfect and didn't have any ripples in them at all were just worn out
