Ox Locker in GMT900 with 3.42 gears?
07CLASSIC
what is your build so far? lift? bigger tires? otherwise there is really no point in trying to fit a controllable locker it likely won't provide any real benefit.
and if you do have a lift and bigger tires 3.42 is probably the minimum to start with.
around here the trails are pretty tight and are jeep trails, trying to fit a suv thru is likely to end with body damage.
Yes, if I'd gone the 4wd route, I'd definitely opt for 3.73's at a minimum. This would be an occasional off-road enhancement for my 2wd. It is what it is for now.
the eaton tru trac should be fine in almost all cases, it's bullet proof that's for sure. (I haven't broke one yet lol) but have broken plenty of g80's
but for a definitive answer you might try reaching out to filthy motorsports I have had there page saved forever for referencing what can be used and what is available
based on the axle/gearing etc they show the OX as a option for "some"
07CLASSIC
the eaton tru trac should be fine in almost all cases, it's bullet proof that's for sure. (I haven't broke on yet lol) but have broken plenty of g80's
Hmm. I was pretty sure I'd thoroughly checked out the Eaton Tru Trac, but I was thinking it was an auto-locker, which I didn't want for certain situations. Now that I see it is NOT, and is a unique limited slip, I may need to take another look at it. Thanks.
I'll def check out Filthy Motorsports.
I referenced them because of the information there page shows and usually video's on various products with a in-depth look at how they work
strutaeng
Dallas, Texas
I think a selectable locker is better for more aggressive off-road use, like a dedicated (or not) trail rig. Why? Because it locks the rear axles so they spin 1:1.
The LSD have some slip between the axles, which is fine daily driving and some mild off/moderate off-road use.
I forget what the Detroit Truetrac is, but I want to say it's an LSD(?) There's different types of LSD mechanism and that particular one is a "Thorsen"-type LSD. The Thorsen differential require you to apply the brakes momentarily if one wheel is in the air to engage, otherwise if behaves like an open differential until you force one wheel to stop.
Probably doesn't matter OP, but you may want look into the differences.
This video I think covers that:
07CLASSIC
I had forgotten about the Torsen design, I've seen videos in the past about how it's used on military vehicles and read about how unique it is. I'm def considering this option more now. We'll see. Don't mind the idea of it always working on its own and it doesn't hurt that it's a good bit cheaper than the Ox as well.
07CLASSIC
Yes, you're right about the Torsen/Thorsen design. That's pretty interesting. I'm researching the pros and cons of both now. Thanks for the vid.
strutaeng
Dallas, Texas
Yes. Pretty interesting indeed.
Honestly, they all have pros and cons. On the selectable locker where they lock 1:1, you can't really steer or turn, because both wheels are turning at the same rate. Going around a corner, the wheels would bind if they have good traction.
Similar to the guys that would weld their spider gears on a daily driver. Not sure why anyone would do that for a daily driver. Driving around a parking lot you have a lot of tire screeching. I guess if you are really poor and have a welder, then everything looks like a nail...-type of thing?
I'm sure you be happy with the Thorsen LSD for your application. :cool:
swazzie
