P0157 Only on hard acceleration
TheEnder53
Hello everyone.
I’m going through repairing everything on my 01 Tahoe.
Right now, on hard acceleration at wide open throttle it sets a P0157. If i don’t drive it hard everything is ok and the code will never set.
02 sensor voltage according to HP tuners for B2S2 is quite low from what i remember seeing with engine off cold. Looking for a direction to go in with this. 02 sensor was replaced with one from Autozone. Didn’t fix it.
Fless
Super Moderator
Elev 5,280
Any exhaust leaks before or right after the cat? Something to cause it to run lean when you're at WOT?
What do the short- and long-term fuel trims look like?
TheEnder53
TheEnder53
From what I can tell, absolutely no exhaust leaks from the exhaust manifold back to the B2S2 02 sensor. Even has all its exhaust manifold bolts still.
If I recall correctly, using HP tuners, short term fuel trims would jump all the way into the positive red (and i think long term would too, i need to look again) until I let off the gas.
TheEnder53
TheEnder53
Apologies for delays too, been very busy with family stuff.
mcclish2012
