P015B code, Broken exhaust bolt?
spectralen
I have the p015B code, bank 1 sensor 1. I switched it with the bank 2 sensor 1 and the same p015B came back after about 30 minutes of driving and would go away at times.
The sensor wires look good and it runs smooth. I do notice that the far rear exhaust manifold bolts on both sides are broken. I can see carbon around the back of bank 1 manifold where the bolt is gone.
My question is has anyone ever had a broken manifold bolt situation cause a P015B ? I have no other codes.
Thanks
I don't believe that broken exhaust manifold bolts will generate a code on their own. I've got broken exhaust manifold bolts and no generated codes.
Other members of this Forum much more knowledgeable than me in this area will chime in.
spectralen
spectralen
I have other LS motors with broken bolts and no codes but I do see where the exhaust is leaking and it’s just above the o2 sensor that’s throwing the code, so that makes me suspicious
bdewitt205
