P0300 and Stumble
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Clean your MAF sensor and throttle body.
Pull out the MAF sensor (like out of the car and unplugged) and hit the hot wire elements with MAF or Carb cleaner. Dry with compressed air (be careful with air pressure if using shop air). You just want to dry it off and evaporate any solvent afterwards.
Pull off the hose going to your throttle body. Turn the key on with engine off and either have someone hold down the gas pedal or use a prop rod to hold the gas/accelerator pedal to the floor.
Go to the engine bay and spray a rag with carb cleaner. Get it wet. Then wipe down the throttle body plate on both sides and also the throttle body bore.
IT may hesistate to start after this so crack the throttle open a little with the gas pedal and crank it. Let it idle 10 minutes and repost your data.
Don't brush the sensor filaments if you've never done it. They are fragile and will break if too much pressure is applied. Spraying them with Carb cleaner gets almost all of the grime off. Just blow through it a few times and make sure that it's dry.
At the end of all this your PCM has to adapt to the new sensor readings so either just start it up and let it idle for 5-10 minutes or disconnect the negative battery cable for 15 seconds. Judging by the data from your scan tool, that tool most likely cannot clear PCM memory by a button push so those are the easiest ways to do it.
Judging by the data you provided this will either help or completely fix your issues. Good luck!
S
swimaway
Hey guys, thanks for the help.
I have now tried all of the above. I still have the P0300 code. I even went as far as replacing the MAF.
Sometimes the idle feels a bit better, sometimes a bit more rough. It seems the more I drive it the worse it gets. If I drive it for a bit, shut down, and go again, it's worse.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Have you tried spraying brake cleaner around the base of the intake or around hoses? If the idle changes, you can get a better idea where the leak is, that is if there is one
S
swimaway
I have tried that as well. No idle changes. Tried the Seafom thing. Lots of smoke, no improvement
S
swimaway
Fuel pressure is 42 at idle. Goes to about 50 @ 2000 rpm at load.
S
swimaway
I have a Centech 60794 - I don't think I can pull misfire data. I'll have to wait until tomorrow to take it over to a shop to have it read
Brynedic
