Have a flashing CEL, super rough idle. This happened 6 weeks ago and went away.Stabilitrack and ABS have been on the whole time. I hooked up a Tech2 and it pulled P0300, P0204, P0206, P0208 Injector Control circuit.
I installed new spark plugs and wires and still have the same problem.
Using a spark plug tester, I have NO spark at all on the RH Passenger side 8-6-4-2. That entire side isn't turning on because its cool. Driver side gets hot when after I turn on the ignition. I swapped a good known working ignition coil on cylinder 2 on the 'dead' side and still have no spark.
Any ideas where I should look?
