Swapped junction (fuse) boxes. Didn't solve misfire on #8. However, the fuses for #13 and #18 are nice and snug now. I will probably keep the replacement box.
Decided to put my original ECM back in the vehicle. NO misfires now, which is great.
My conclusions after all of this:
I am attributing the Entire Bank B misfiring as a loose #13 fuse slot on the junction box. My new junction box slot is very snug, the old box (specifically #13) is not.
I am attributing the misfiring on #8 as a bad ECM.
None of my coils were bad.
None of my spark plugs or wires were bad.
My grounds were good.
Crazy that these shops misdiagnosed things and so poorly. As stated before one guy wanted almost $1300 to swap the entire harness and ECM. Another shop said I had a bad coil and bad X2 connector for engine harness to ECM and wanted close to $1200 for the diagnosis, replace the coil and repin the X2 connector. That connector took me all of 30 minutes to repin. Doing that and finding out my coils were good saved me $600
I am now getting a P0113 Intake Air Temperature Circuit High Input. I'll look into that when I get a chance. I found a thread on it here, with the most value coming fro vietvet's post.
www.tahoeyukonforum.com
P0113 ?
Had no engine light, scanned for codes and got 3 codes p0113 Intake Air Temperature Sensor 1 Circuit High Bank1 p2227 Barometric Pressure Sensor p2228 Barometric Sensor never seen this kind of code, Bad MAF sensor? P.S. 2016 Tahoe PPV
