Hi all,
My 2002 Yukon is running a bit poorly these days.
It's got 250,000 kms (roughly 155,000 mi) and maintenance history is largely unknown. I've had it for about 15,000 of those kms and haven't done much other than oil changes.
Started hesitating under load a couple months ago. Just a bit of stuttering at freeway speeds when I give it a bit of gas. Got a bit worse this week. Got flashing check engine lights, and now a steady check engine light. Pulled a P0301 code (misfire cylinder #1).
Initial plan is to replace spark plugs and wires. I have no idea if they're original or have ever been changed. Can't hurt things. Hoping they fix the problem.
Is there anything else I can / should check before ordering the parts?
I'm not driving it much now that I've gotten the check engine lights.
