P0301
Kelsda
Kelsda
New Jersey
4B89F24B-0DEB-48F5-AEB6-11DE75184553.jpeg 43E7D5B9-7652-4A2D-AC5F-E447ACFD4F1A.jpeg A16FC640-076B-4F36-A365-91471EE683BB.jpeg 6A295E5F-8779-4F8F-8D24-34A3116A0793.jpeg 8B518B51-712D-49C4-89A1-2B1F10AE5684.jpeg Didn’t go out last night was in the mid 20s All pulled apart. Anyone have a suggestion what to clean the lower intake with, I've seen people say they bring it to a shop to have it cleaned.
Is it blasted,parts washed, boiled in a solution, brake cleaner, or mineral spirits what would you do? Thanks
liquify33
Houston
That’s not bad IMHO, just make sure mating surfaces are nice and clean. I had some putting in the front corner/#1&2 area but sealed fine. Carb cleaner, wheel brush on a drill, some sandpaper and elbow grease. That’s by far the crappiest part of the job.
Kelsda
Kelsda
New Jersey
C4887FB9-6C38-4D52-9343-1686756036EC.jpeg 2492B7A7-FCDC-477F-BADF-99440FF956C7.jpeg BBD535B7-64EA-4B8C-9342-F39AF14D2674.jpeg
What about this can’t see other side do you think this is a crack or just in the casting and what are these holes for not all in the same spot like random one is right on the edge of the injector hole
exp500
That does look like cracks. Is there water on the other side? didn't look like it but you are there. If it is only intake valley you should be ok. Intake Manifolds around here are 35-40 junkyard.I haven't seen one crack before. Try a drop of acetone on crack to verify its not a scratch. It will pull right into crack.
Kelsda
Kelsda
New Jersey
I need this rig fixed the Jeep Wrangler is killing me windy and cold start tomorrow putting back together
Multnomah Falls
Make sure you keep it very clean during reassembly and IMO, you cannot go wrong with Fel-Pro gasket kits. Better than OE in many instances.
kielyr
