P0302 - Misfire Cylinder 2: need help troubleshooting
07 black beauty
Richland, Michigan
Do or have a compression check done on cylinders. With a 5.3 that has AFM\DOD, most likely it will be a lifter issue.
and if it is related to AFM and you have it repaired, please get the AFM crap deleted or at least disabled.
D
DesertRat
checked compression on the front four cylinders, all were around 170/180. I'm going to check wires next. I disconnected the #2 injector wire and no noticeable change. Just have to take the time to chase the wires and check continuity
D
DesertRat
maybe a bad injector, maybe it has a intake leak?, I would test for a intake leak and maybe swap injectors
This looks like it might be the winning answer. Last weekend I replaced the intake and valve cover gaskets, and I noticed an immediate difference at idle and overall performance. Gasket at cylinder #2 was noticeably not sealed correctly. Even after idling for prolonged periods of time this week, the CEL did not come back on. It's only been a week though, so it's not been thoroughly tested.
After rereading my first post, I should clarify that in most instances the CEL came on after idling for several minutes.
juantavarez127
