P0307 misfire
Blacksabby
05 Tahoe. P0307 misfire cylinder 7. Getting spark and compression at 160. Spark plug was dry when I removed it. Anyone heard of a cracked intake manifold or clogged injector causing this code.
Fless
Super Moderator
Elev 5,280
Moved you here from General Discussion since this is an Engine & Drivetrain issue.
rockola1971
Indiana (formerly IL)
Any part that keeps spark, air or fuel from getting to a cylinder at the right time and in the correct quantity can cause a misfire or no fire at all. You need a bidirectional scanner that allows you to fire injector to verify a fine conical shaped mist of fuel is coming from its tip. What color is the plug tip?
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving sage advice from the knowledgeable folks on this Forum. Other members of this Forum much more knowledgeable than me in this area will also chime in.
Gibbsy74
