04
hi you need to get the updated part for the canister purge valve solenoid the one located by fuel tank not by engine the GM part number 15086768 i order it from GMPARTSGIANT.COM for $114 and it solved the p0446. if you go to dealer they want about $400-$600 to fix. just get the part and take it to your local mechanic and install and make him smoke check canister and fuel system to make sure no leaks i also recommend you order brand Oem gas cap Acdelco do not get the one with keys they always leak air.
NOS Genuine GM 15086768 Hose Evaporation Emission System
