Funny you mention this, on my old 2000 Z, the plastic hinges had become brittle and wouldn't keep the switch depressed for the vanity lights above the visors (both sides, too). Drove myself crazy trying to find the drain. Couldn't believe it when I found it to be that. I stretched rubber bands around the visor to hold them closed! Lol
Damn it man! did you just happen to notice it or did you have to chase down the draw? someone who never uses those mirrors or visors would never think to check those either.
It's funny you mention the ignition. There is a relay below steering column that was put in after market. I began cutting the under dash lights out and it looks like it was part of the lights. I cut it off with side cutters and shorted the wires past the relay and it began cranking so I know it was to ignition but it looks to me that they used the ignition wiring to power the lights via a controller but this was spliced into the ignition wiring. I pulled that relay out and it will not crank. Should I cut above the relay and splice it?
