I got rained on with down windows. I rolled my passenger window up and it will not come down. Upon further investigation I found that when the switch is plugged in it automatically operates the motor and will not stop, and this is what burnt up the first window motor. Does anyone know if this is an issue with the relay or the switch? You can stop the motor if you push the switch to make the window go down but when you release the motor functions by itself. The door lock works fine.
Thanks,
Thanks,
