I had a issue that seemed to be the passcode sensor, so ordered new housing with the sensor and changed out the column parts. Also put in a new ignition switch ( the electronic wire harness component that does the actual work, not the key and cylinder).
All is installed, and same symtoms. Have done the 30 minute 3 cycle re-learn process and nothing changed. Get crank, fuel relay not connecting and engine won't stay fired, so only get a couple seconds operation.
Am I now going to the BLM module? Or other suggestions?
